'82 Accumulator Replacement Help!
Old Jun 1, 2014 | 11:45 AM
scorpion18z's Avatar
scorpion18z
Default '82 Accumulator Replacement Help!
Can anyone give me an idea of what’s involved in replacing an A/C Accumulator in a 82 Vette? Pictures and/or videos would certaining help. I have made the R-134a conversion by replacing necessary orifice tube and connection points. Has been working, but I feel that I should have replaced the 32 year old accumulator for more efficient operation. Thanks in advance, John
Old Jun 1, 2014 | 07:38 PM
scorpion18z
No one has changed out their accumulator on the a/c conversion to r134a. I will be the first to do so?
Old Jun 1, 2014 | 08:04 PM
dugsgms74's Avatar
dugsgms74
Changing it is a good idea especially if youre gonna change the oil type or if it was completely empty. If there was still some pressure in the system then chances are no moisture got into the system(the accumulator holds the desiccant bag). Cant help you with the replacement procedure though, never done one.
To '82 Accumulator Replacement Help!
