'69 minor resto project
Old Jun 1, 2014 | 04:08 PM
Fstdraw's Avatar
Fstdraw
Default '69 minor resto project
I'm doing a little work to the old gal while I'm waiting for my new 406 to be completed. I want to replace the rubber bushings all the way around and I'm installing rebuilt trailing links. So, if you'd be so kind, rubber or poly bushing kit, and what is the proper or best paint to use on the suspension pieces and on the engine compartment? Thank you.
Old Jun 1, 2014 | 05:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Stock rubber bushiings are fine for a driver. Any semi-flat black for frame, suspension, and under the hood. A-arms and brake boosters have a decided glossy look to them.
