"82" oxygen sensor"
Old Jun 4, 2014 | 10:28 AM
donaldbly's Avatar
donaldbly
Default "82" oxygen sensor"
Did a "code dump" on my 1982 and it showed a code 13 which is oxygen sensor. My question is (1)where is the oxygen sensor (2) how do I replace it and (3) is this something that can be purchased at Autozone. I do have Hooker Headers does that make a difference as to what sensor to purchase?
Old Jun 4, 2014 | 11:05 AM
Arkyvette's Avatar
Arkyvette
On the factory setup, its in the pipe near the cat. You can see it from the passengers side looking up. As for removing a 30 year old part from the exhaust....i don't know. I'm about to cross that road. I do have the O2 sockets for installing the new one, but normally cut the wire and use what's best for removing old ones. if your O2 is in the factory location, a stock one should do fine. My biggest fear is ending up with an entirely new exhaust from trying to change one sensor.
Old Jun 4, 2014 | 12:27 PM
jnealg's Avatar
jnealg
PB blaster is your friend in this case. spray every day for a week before attempting. the store sells an oxygen sensor removal wrench that helps sometimes.
Old Jun 5, 2014 | 07:25 PM
alconk's Avatar
alconk
Just curious are you still running the fuel injected unit? I assume you are since you're messing with the computer. Since you're running headers (long tube or shorties?) I'd go with a heated 02 and will make a big difference.
To "82" oxygen sensor"
