Rookie needs damper piston exploded view
blow up........die.......cutting........(watc hwords!)
Well......now the NSA is watching BOTH of us....LOL/kinda/LOL!
EDIT: Several hours later..................
OHHHHHHHHHHHHHHHHHH....I get it!
(I am s-l-o-w!)
"blow up"=====exploded view......!
After drilling (revised step: AND TAPPING FOR A TAPERED PLUG (for theOEM-Look--the hole would be welded after filling with oi & burping)a 3/16" diameter oil-fill-hole in the other end-cap and assembling the pieces in the correct order, the end-cap that was cut off (without damaging the internal pieces).....was beveled so the weld would penetrate better. The end-cap has to be compressed to butt against the main barrel since the rod seal is spring-loaded against the end-cap to seal properly/then the end-cap is tapped side-to-side to re-align it using a straight-edge against the barrel. Then...with NO oil in the barrel, weld-tacks are placed 180* apart every 1/4"or so to hold the end-cap securely in place. Then the Mig welder is turned to the lowest heat setting that will still provide a good weld...and then a continuous weld is made around the barrel gap while the end-cap and rod are submerged in water within 1/4" of the area to be welded to keep from damaging the internal seal on the rod...(It appears that GM used a special material seal so the welding process wouldn't ruin the seal...since I doubt they used the bucket of water-trick-LOL...............ALSO...blasting the end-cap with compressed air after welding it would be easier than the bucket-of-water-trick-LOL![/COLOR]
Then the end with the fill-hole is held upright (gently) in a vicce.oil is injected into the hole while the rod is moved in/out an inch or so (less movement as the air is burped out and the oil reaches the ffill-hole. Then-tap a short metal "plug" flush into the fill-hole and weld it "shut".....air cool the weld...then paint the damper your favorite color of Black.
I think I said that correctly/in order (PTSD/ADD/WXYZ/ETC.
