Deliberate mispelling, so please don't respond to this post, because I don't want a search pulling it up. Don't be the first guy to blurt it out on the response. This is fr u guys only as an idee that I came up with on the fly lst n1te.
Discovered a method for G3tting into your l0ck3d C car. if you left the Kyz inside. Because, that's what I did last night, after de Kingz gam3!
P0ndered what to do, had t0e truck on the way and noticed that I left my wndoez slitely 0pn. I manged to get my fingrz insid3 and tho it wasnt ez, I fnd that u can pp the t tp! Stk ur fngrz up 1n the grvs and pul the lvrz dn, 1 by 1 and the t tp comz off! Rtreve kyz and ur gd.
Pretty sure thieves figured this out a long time ago. When I first moved the car to a new house a few years ago I accidentally locked the keys in once with the engine running. I used this "trick" to get in.
Depending on how tight your t-tops are, make a fist and give a firm pound right above the t-top latches. If they are loose enough, they will drop open. I've had them fairly tight and this method still worked.
I can imagine, what that would look like to passerby! Some guy, beating his fist on the roof of his C3!
So... why weren't we supposed to respond to the OP?
Thread Fail! Didn't want to unnecessarily desseminate sensitive info, but I guess that's all blown, now! Learn something new, everyday. T-top locks, beating on the roof, radiator hose tools and I imagine this crowd has even more interesting methods, up your sleeve!
