Battery Direction
Old Jun 12, 2014 | 06:19 PM
Tom73's Avatar
Tom73
Default Battery Direction
Dumb question but should the battery terminals be on the front or back side of the battery when in the car? Terminal to the front or to the rear?
Tom..
Old Jun 12, 2014 | 06:27 PM
Peterbuilt's Avatar
Peterbuilt
Rear on my car.
Are mine right or wrong?
Old Jun 12, 2014 | 06:29 PM
Richard Cooper's Avatar
Richard Cooper
My 81 has the terminals facing the rear of the car.
Old Jun 12, 2014 | 06:31 PM
havesometo's Avatar
havesometo
80 facing the rear of the car.
Old Jun 12, 2014 | 07:33 PM
David Mc's Avatar
David Mc
'72 facing the rear
Old Jun 12, 2014 | 07:48 PM
Carl Granquist's Avatar
Carl Granquist
Default A.i.m.
Page L255 says rearward. I'm on my second battery since the previous owner. Actually, I don't think the cables will let connect any other way.
Old Jun 12, 2014 | 07:51 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Depends on what you consider the front or back of the battery.
Old Jun 12, 2014 | 08:05 PM
early shark's Avatar
early shark
On the '71's I don't think the cable orientation will allow the battery terminals to face frontward.
Old Jun 12, 2014 | 08:35 PM
DonnieP73's Avatar
DonnieP73
Tom..
On page 375 of the 73 AIM shows that the terminals are towards the rear of the compartment.
Donnie
Old Jun 12, 2014 | 11:14 PM
Tom73's Avatar
Tom73
Thanks to all for the responses. I just wanted to confirm that mine was right.
Tom...
Old Jun 12, 2014 | 11:40 PM
PeteZO6's Avatar
PeteZO6
1969 was the first year with side post batteries. They had the terminals on the front side. It's very difficult to access the terminal bolts unless the hold down clamp is released and the battery is tilted toward the back of the car. The cables are too short to turn the battery around. I think '70 was the first year the battery was rotated so the terminals were on the back side, with cables that reached.
Pete
Old Jun 13, 2014 | 01:23 AM
dugsgms74's Avatar
dugsgms74
Just a side note, most cars will have the negative terminal out board so in a collision there is less of a chance for the positive terminal to contact metal(less of a issue in a fiberglass car)
Old Jun 13, 2014 | 05:55 AM
oldgto's Avatar
oldgto
Since the battery is only 6 inches away from my a$$.... in the event of a collision, the positive post touching metal would most likely be the least of my concerns!
Old Jun 13, 2014 | 10:16 AM
pws69's Avatar
pws69
69 - Terminals to the rear.
I use battery's with BOTH side and top posts - more convenient for attaching a tender/charger
To Battery Direction
