R134a Will it cool a 79?
I remember reading that a larger "squirrel cage" with improved blades was the reason for the air flow improvements.
to do this right, we really need to cut the right fender liner out of there, and so remove the blower assy, and vacuum out the leaves and crap from the pressure side of the evaporator coil....huge PIA, and unlikely to be done by any HVAC shop.....
and so when doing that, I noted that stupid air flapper on the wall, it's the valve that makes outside air or inside air when combined with the one under the right side kick panel.....recirc vs outside.....
MY car has been sealed up, but it's a convertible....plenty enough outside air even with top UP.....so the outside/wiper valley door is sealed shut, and the inside door removed......it's always on recirc....
I have an '88-91 compressor, new valves and stock evap, and condenser.....puts out 50f air on 100f ambient at 100% humidity.....should see the **** pattern down the drive.....regular flood zone.....
