Oil Filter Adapter Question
Old Jun 18, 2014 | 06:50 PM
Cavu2u's Avatar
Cavu2u
Default Oil Filter Adapter Question
This part is missing on my 383 project engine:
While I have one on order, I cannot find any illustration/exploded view of it's assembly. My question is; Is there any gasket between this part and the engine block to which it is mounted on?
Thanks in advance.
Steve
Old Jun 18, 2014 | 07:22 PM
jnb5101's Avatar
jnb5101
I don't think a gasket is used, but I always use a very thin smear of RTV.
Old Jun 18, 2014 | 07:23 PM
Pete79L82's Avatar
Pete79L82
Thanks in advance.
Steve
No gasket used.
CA-Legal-Vette's Avatar
CA-Legal-Vette
No gasket. Just 2 bolts.
Old Jun 18, 2014 | 08:08 PM
Cavu2u's Avatar
Cavu2u
Okley Dokley.
Old Jun 18, 2014 | 08:25 PM
hamck's Avatar
hamck
I have a question If you don't mind. Theres a bypass in the adapter correct? If you have high oil pressure pump,(I have 50 psi) Will the filter be bypassed and not clean the oil properly?
Old Jun 18, 2014 | 08:30 PM
'75's Avatar
'75
The bypass works on a differential pressure. It will bypass if the pressure on the inlet and outlet of the filter are too different. Higher oil pressure should not affect it. It's designed to bypass if the filter is plugged or the oil is too cold to flow through at the rate the oil pump is pushing it.
Old Jun 18, 2014 | 10:21 PM
Cavu2u's Avatar
Cavu2u
Old Jun 19, 2014 | 07:05 PM
hamck's Avatar
hamck
Thank you Now I understand
To Oil Filter Adapter Question
