timing L48
Old Jun 24, 2014 | 07:33 AM
red topless gator's Avatar
red topless gator
Default timing L48
Anyone know the correct timing for a 1974 L48. Some manuals say 8 degrees BTDC some say 12.
Old Jun 24, 2014 | 10:34 AM
F22's Avatar
F22
I just happened to drive 'Sassy' (1974 L48) into work today. I'll check the timing decal. It's different for an automatic, versus a manual and I'll give you the details in a bit.
Old Jun 24, 2014 | 11:07 AM
Mike Ward's Avatar
Mike Ward
What does the GM manual and the sticker under the hood say?
Old Jun 24, 2014 | 11:15 AM
F22's Avatar
F22
The sticker says:
Automatic 8 degrees BTC @ 600 RPM
Manual 8 degrees BTC @ 900 RPM
Old Jun 24, 2014 | 11:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by F22
The sticker says: Automatic 8 degrees BTC @ 600 RPM...Manual 8 degrees BTC @ 900 RPM...
Hmmmm. I would toss the manual which says 12 unless it's a California car.
Old Jun 24, 2014 | 02:15 PM
Rally68's Avatar
Rally68
Any reason you want to stick with the factory spec? The way I understand it, GM significantly detuned these engines and they can really benefit from a modified timing curve, especially a little more initial timing. The book spec on my '68 327 is 4 deg BTDC; I re-curved my distributor to run 12 deg initial and about 34 deg total (just over 50 with vacuum advance IIRC) and the car runs so much better--and cooler.
Old Jun 24, 2014 | 07:07 PM
Cavu2u's Avatar
Cavu2u
And don't forget to remove & plug the distributor's vacuum advance line when timing it.
Old Jun 25, 2014 | 09:19 PM
kdf1986's Avatar
kdf1986
There is more to setting the timing than a simple question. If all things are stock, and you want to set it to the stock setting, then some of the answers above can help. If you are setting the timing for best performance then the initial, mechanical and vacuum advance timing need to be checked, with the total timing i+m+v not exceeding 52 degrees.
Initial of 12 degrees can be a good setting, which may help to push the mechanical advance to around 36 degrees. I am hoping that others with more timing experience will join in at this point.
kdf
Old Jun 25, 2014 | 09:31 PM
red topless gator
Thanks to all with their thoughts, gives me something to ponder.
To timing L48
