Drop small block in with headers?
Old Jun 27, 2014 | 09:14 PM
Shark Racer's Avatar
Shark Racer
Default Drop small block in with headers?
I'm doing my engine drop tomorrow. Does anyone know if it's possible (easy) to drop a small block in with headers attached, or should I save that for after it's bolted up?
Thanks!
Old Jun 27, 2014 | 09:18 PM
MrJlr's Avatar
MrJlr
I set mine in the engine bay and tied them out of the way. Then I dropped the engine down in between.
Old Jun 27, 2014 | 11:25 PM
donyue's Avatar
donyue
Thanks!
Attach the headers after you put in the engine. That way they won't get banged up and scratched etc. JMHO.
Old Jun 28, 2014 | 08:34 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Old Jun 28, 2014 | 10:00 AM
qwank's Avatar
qwank
I've used two totally different types of long tube headers and they both slid in from under the car easy enough that I don't consider it a chore to remove and replace them
Old Jun 28, 2014 | 01:09 PM
AirBusPilot's Avatar
AirBusPilot
You could probably get the engine 80% lowered into the frame, then slip the headers in from above, tighten them down and be good.
Old Jun 28, 2014 | 01:32 PM
Sunstroked's Avatar
Sunstroked
Long tube Header installation after engine drop was a piece of cake for my 72.
Old Jun 29, 2014 | 12:29 AM
C3 Stroker's Avatar
C3 Stroker
Put the engine in first......it took only 10 minutes to install my Hooker Super Comps afterward. Headers go in easier than a spark change on small blocks.
Old Jun 29, 2014 | 01:35 AM
Shark Racer
I put the engine in. That would have been a cluster fsck with the headers on. It was only slightly annoying with out them. The power steering pump was a bit of a problem, I left it hooked up to try to minimize the pain of having to bleed it out... that was a mistake, but we got it done.
Thanks for the advice, everyone.
To Drop small block in with headers?
