AC not working correctly, 1982 Corvette
Old Jun 29, 2014 | 03:36 PM
VCorvette's Avatar
VCorvette
Default AC not working correctly, 1982 Corvette
Hello Dear professionals
I charged my AC system that wasnt charged for a long time.
And after I charged it this is how the AC compressor is working(turns on and then turns off every few seconds) Here is the link for the video I took of my AC compressor working:
Any ideas what could be the problem and how I can fix it?
Thanks in advance for your advice.
Old Jun 29, 2014 | 03:43 PM
vbgod1's Avatar
vbgod1
Rapid cycling like that, to me, says check for low freon charge. You should look along the line by the right fender for a sight glass, and see if you see bubbles in the line. Add a little freon until the bubbles go away. Most likely need to find the leak.
Old Jun 29, 2014 | 05:00 PM
LS4 PILOT's Avatar
LS4 PILOT
Yup
Low Gas
If it is 134a
Did you pull a vacuum on the system , if it was completely empty of freon , then it was full air and moisture.
Put a vacuum pump on it .....if it won't pull down .....then it needs addt. help......fix leaks , replace dryer etc.
Go down to Dollar General
Buy a can with the hose .
Connect to low side port ,with engine running and AC on, squeeze handle to start transfer , give it five , or ten minutes once it's ....to get worked though the system.
See if that helps slow the cycling down and cool you too.
If not report back . I have had to add two cans to some of my other vehicles to get a full charge .
It should stay in at least a year ...or you need to find the leaks ......maybe hoses or schrader fittings ...very common
Old Jun 29, 2014 | 05:01 PM
VCorvette's Avatar
VCorvette
Thank you for your answer
I didn't find sight glass.
So, do you thing problem is not in the compressor? Just leak somewhere?
Old Jun 29, 2014 | 05:11 PM
VCorvette's Avatar
VCorvette
Originally Posted by LS4 PILOT
Yup
Low Gas
If it is 134a
Thank you!
Old Jun 29, 2014 | 05:29 PM
qwank's Avatar
qwank
how much freon did you put in?
Old Jun 29, 2014 | 06:54 PM
VCorvette's Avatar
VCorvette
1,5 cans 134a leak sealer + UV dye, 10.25 oz per each.
Looks like leak somewhere. Now the compressor does not turn on
Old Jun 29, 2014 | 07:20 PM
qwank's Avatar
qwank
must be a pretty big leak.
I run 1.75 lbs of freon in mine.
so you need about three 10.25 oz cans to get it completely full. everyone around here sells 12 oz cans. I just charge it with the machine at work.
Old Jun 29, 2014 | 07:55 PM
vbgod1's Avatar
vbgod1
At least you can look for the dye and find the leak.
Do you have a wire connected to a switch on the back of the compressor? High pressure cut out switch?
Old Jun 30, 2014 | 07:04 AM
VCorvette's Avatar
VCorvette
Just this wires
http://forums.corvetteforum.com/atta...1&d=1404126134
Old Jun 30, 2014 | 08:06 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The original system was R12. Has your car ben converted to R134a?
Old Jun 30, 2014 | 10:38 AM
VCorvette's Avatar
VCorvette
I just screw on adapter from Advance auto parts
Old Jun 30, 2014 | 11:06 AM
chvet73's Avatar
chvet73
I have close to 3 cans of R134 in mine.
To AC not working correctly, 1982 Corvette
