Disappointed with Quality of Reproduction Fan Shroud
Just wanted to share my disappointment when I opened the box with my new fan shroud that was at my doorstep when I got home today. I was excited to open it...but that quickly changed. This is probably one of the worst reproduction parts I have ever received. Not quite sure how the vendor makes them, but it appears like the shroud is made in a couple of pieces and then somehow bonded together? I am planning on returning it back to the vendor I purchased it from tomorrow. Haven't decided if I will ask for a full refund or give them one more shot at sending me a better one. Take a look at some of the photos below and you will see what I mean. Have any of you ever ordered a reproduction fan shroud that looked like this???
Lots of Pics!
Lots of Pics!
Nam Labrat
Received 4,322 Likes
Just a suggestion:
You'd better send the pics (with the questionable areas highlighted with a marker) back with the shroud....the vendor might not have a clue as to how a reproduction shroud should NOT look.
Looks used to me. Hope it works out for you.
At first glance of the shroud, it seemed to be used, but it is not. Just a really poor attempt at trying to reproduce the original version. Seems like the vendor did not spend a lot of money on designing the mold to make the shroud as evidenced by all the blemishes, rough and unfinished edges, and poorly formed/trimmed bolt holes.
I tried placing arrows on green painters tape and sticking it to the shroud to point out all the areas that looked horrible so they can see why I am returning it, but the shroud seems to have a lot of mold release chemical on it or something and the tape will not stick. I am hesitant to use marker for the fear they will not accept the return and allow me to exchange it with it all marked up.
The photos of all the bad spots on the shroud are hard to see, but trust me, this shroud is definitely not one I would be proud of if I installed it on my Corvette.
Going to give them one more shot at sending me a replacement that is hopefully in better condition. If the next one is just as bad or worse, I will ask for a full refund!
Here is a prime example of why original parts are sky high.
Most repro parts are cheap, poor quality junk, that doesn 't work, last ,or look correct.
