Water pump belt
Old Jul 2, 2014 | 09:35 AM
Young Bill's Avatar
Young Bill
Default Water pump belt
Hi All,
Been out running around in the old C3 a fair bit. My steering however was feeling a bit juddery on low speed movement and the belt looks real loose. I've had a new belt delivered so now planning to change it. Any guides or advice on how to go about it best would be most appreciated. I've had a search through and can't find anything..
Hope you are all well and enjoying summer
Old Jul 2, 2014 | 12:25 PM
MelWff's Avatar
MelWff
well if other belts such as alternator are in the way they have to be removed first. Then loosen the PS adjustment nut and push the pump towards the center of the car to remove the belt tension.
Old Jul 2, 2014 | 12:38 PM
Young Bill's Avatar
Young Bill
Cheers amigo, I'll have a look at the AIM for the nuts. Gonna change the alternator as well so reckon that will make it easier. The air con has been deleted, not something we really need in Scotland in a T top
Old Jul 2, 2014 | 02:45 PM
Kevin68's Avatar
Kevin68
The power steering belt does not go to the water pump, only the harmonic balancer (at least on my 68). The AIM has the correct belt routing.
If no AC, then just loosen the bolts and slide the top of the PS pump to the right. The alternator belt is aft of the PS belt so you don't need to touch that one. There are three bolts to loosen. One that slides in the PS pump bracket at the top of the pump reservoir and two at the pivot point at the bottom of the pump, one forward and one aft.
Old Jul 2, 2014 | 03:14 PM
AirborneSilva's Avatar
AirborneSilva
Same as mine - 76
Old Jul 2, 2014 | 03:38 PM
Young Bill's Avatar
Young Bill
Originally Posted by AirborneSilva
Same as mine - 76
Thanks guys, I've changed over the alternator belt. just need to get onto the PS belt. It was really badly worn and ready for breaking.
Old Jul 3, 2014 | 01:48 PM
Young Bill's Avatar
Young Bill
Both belts replaced and test flight complete. Power steering is working a treat, no juddering or sqeaking... Thanks guys for all your help.
To Water pump belt
