CF 70 LS5 454 owner thread
Old Aug 7, 2017 | 02:45 PM
  #841
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Duntov will stop there tommorrow and take pics for you.
Old Aug 7, 2017 | 04:51 PM
  #842
jr9170's Avatar
jr9170
Duntov hope these help
Old Aug 7, 2017 | 11:06 PM
  #843
Duntov's Avatar
Duntov
Yes very much so. My top cover touches the washer pump, which I'm not a fan of. 5 port washers aren't sold anymore. Thanks for the photos.
Old Aug 8, 2017 | 01:05 AM
  #844
jr9170's Avatar
jr9170
Old Aug 9, 2017 | 03:45 PM
  #845
Duntov's Avatar
Duntov
The carb is back so it should be running again soon.
Old Aug 9, 2017 | 04:36 PM
  #846
jr9170's Avatar
jr9170
Got mine back today also.
Old Aug 10, 2017 | 03:02 PM
  #847
jr9170's Avatar
jr9170
Carb on my friend fired it up running smooth sounds great. Have to go over everything have to put all new actuators on should have it back next week sometime.
Old Aug 10, 2017 | 11:56 PM
  #848
Duntov's Avatar
Duntov
Put mine on and fired it up as well. Runs good, but the fuel line to carb is leaking. Likely will swap different inlet fitting on, but still exploring solutions. There is a surface defect on the seat of myinlet fitting that is olddamsgr. The joys of working on 47 year old cars.
Old Aug 11, 2017 | 02:33 PM
  #849
jr9170's Avatar
jr9170
Carb Back on gotta change all the actuators
Old Aug 11, 2017 | 11:41 PM
  #850
Duntov's Avatar
Duntov
Got mine running with no leaks today. Had to change the fuel inlet fitting. There was a burr or surface defect on the original and wasn't confident it would polish out without still leaking. Adjusted the power steering and alternator belts to make them tighter, since one of them started to squeal at startup. Hoping that Sunday I can get some additional timing into the car, to help with idle, power, mileage, drivability etc. Not sure how much timing will be added since want to make sure not getting detonation type issues. Currently have 6 deg BTDC, and likely will do incremental adjustments.
Old Aug 12, 2017 | 02:24 AM
  #851
jr9170's Avatar
jr9170
Old Aug 12, 2017 | 12:54 PM
  #852
jr9170's Avatar
jr9170
Headlights and some fine tuning
Old Aug 12, 2017 | 01:48 PM
  #853
jr9170's Avatar
jr9170
Old Aug 12, 2017 | 01:51 PM
  #854
jr9170's Avatar
jr9170
Can't wait to get it home and Drive
Old Aug 17, 2017 | 01:30 PM
  #855
jr9170's Avatar
jr9170
Headlight washers and actuators came today may chenge rear spring also
Old Aug 19, 2017 | 02:33 PM
  #856
jr9170's Avatar
jr9170
Old Aug 20, 2017 | 10:50 PM
  #857
Duntov's Avatar
Duntov
Took mine out on Saturday and noticed on the way home it was pinging a little if I got on it. Today checked the timing and apparently my dad forgot to add 6 deg to the number since I had marked the timing tab. I marked the timing tab at 0 and then retained it. 26 deg initial is a bit much, so dialed it back to 15. Good thing I put some octane boost in yesterday before going out. Put the shielding back on and spaced it out better between the washer pump.
They claim it's going to rain this coming weekend, so might tackle the headlight and wiper canister seals.
To CF 70 LS5 454 owner thread
Old Aug 20, 2017 | 11:20 PM
  #858
MRANT212's Avatar
MRANT212
Originally Posted by jr9170
It's not often you see a shop with 3 C3's in it. Where's the shop located in NJ?
Old Aug 21, 2017 | 12:08 AM
  #859
jr9170's Avatar
jr9170
Yes shop is in North Jersey very good friend of mine, there was 4 there couple weeks ago. The Orange 72 will be in Carlisle for sale.
Old Aug 21, 2017 | 12:12 AM
  #860
jr9170's Avatar
jr9170
Duntov looking good...
