a - back fire
Old Jul 9, 2014 | 05:19 PM
allben's Avatar
allben
1st Gear
Default a - back fire
hey, guys I some help I have a 74vette 350.with 82.000, in the past I notice my tach was not running the way it should be /the engine also, the tach should run with the engine . am I right when I shut the engine off the tach will freeze, then the engine will run very rough.until the the tach runs good again. then and only then it will run fine . any suggestions will help. thxs
Old Jul 10, 2014 | 08:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The stock tach is mechanical. It should drop to zero when the engine stops.
When was the last time you tuned the car?
Old Jul 10, 2014 | 03:43 PM
dochorsepower's Avatar
dochorsepower
If you shut the engine off, how does the engine run very rough?
Huh?
Old Jul 10, 2014 | 04:38 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
After-running. A good tune-up and setting the timing should fix that.
To a - back fire
