Vintage Air purchase
I've almost convinced myself to purchase a Vintage Air a/c system for my 72 while I have the interior out. I don't want to spend anymore money on the factory a/c system.
I was planning on buying from Summit for the price break using Summit Bucks and their free shipping. My concern is that if I have a problem during the install Vintage Air might not want to help me out since I purchased from Summit and not directly from them.
Anybody run into this?
I bought mine from a company that has since gone away but when I had a couple of questions, the Vintage Air rep was great help. I'd say buy from who you want.
as long as summit is an authorized dealer you will be fine. summit also has some of the best customer service out there.
The best thing about the VA system over the factory system, is you can install it and worry about something else. Mine is 2 1/2 years old and living in Florida, it gets plenty of use. Once the inside of the car cools down, I usually have to lower the fan speed or freeze. I also installed an electric fan in front of the radiator which kicks in when I'm stopped at a light, etc.
I just came back from the Destin, Santa Rosa Beach area and hearing it cools your car down that much is a good endorsement for Vintage Air.
I'm in the process of installing a VA into my 72. I bought from zip. Although the install itself seems fairly straight forward, a few things you may want to consider.
Re: insulation. I'm installing dynamat and dynaliner on the firewall and dash while accessible. You may want to do the same.
Re: polishing or plating/powdercoat of compressor brackets.
The polishing of a compressor isn't cheap, around $125 in my area. If it's something you are interested in, find out if you can pay an upgrade fee for a polished one. Cheaper than having it done. Also the brackets come bare steel. Chroming them was $85 locally. Just something to consider.
Other than that, 1 other installation glitch I found was with mounting the evaporator unit itself. The directions are conflicting. Page 14 tells you to use firewall templates and drill holes in the firewall. Don't. Page 17 tells you to utilize the firewall cover itself as a template and drill the outbd (left) hole. That's correct.
All in all a nicely engineered unit.
Thanks for the tips.
I was planning to Dynamat the firewall, but I'll have to look into Dynaliner also.
Did you buy the Electric Fan Kit (VA Part #302686-CCA) also? If so, how is the clearance between the fan placement and hood...real tight?
No I didn't. I'm still running the stock clutch fan. If I go electric I'll get something a.long the lines of what Dewitt's sells. I'm using 1 of their radiators. But I wouldn't think the VA fan would interfere with the hood, but it may interfere with my electric headlight motors.
I see tim71 got you a picture but I will also get you one either tomorrow of Saturday. It makes a big difference.
The previous pictures were taken with body on a dolly. Here is one with body on the frame. I have Hooker side pipes and a LS engine. If you need pictures of the condenser and the front of the Radiator let me know. I do not have the lines and pump installed yet.
Hope it gives you a idea on how much room you gain. I did not convert it for the room but did not want to deal with the vacuum requirements on the stock system. The VA system does not use any vacuum.
The electric fan will keep the hood from opening aii of the way but still plenty to do any work needed. I had to actually shorten the bracket shaft or what ever the correct name for it is where the hood will stay up by itself. I only cut a couple of inches off with a Dremel.
Vintage Air customer service is excellent...regardless of who you buy it from...
I have two Vintage Air systems and love them both....Had great luck with them... After wasting about $2k on the factory AC system trying to keep it working right, I made the switch..... Wish I had done it sooner.
Make sure to NOT buy from CopperHead racing/automotive on ebay..... They were the cheapest on VA kits but it was a classic ponzy scheme.... Luckily I got my money back from them and went through a local VA dealer..
The deed is done. I purchased from Summit and it will be dropped shipped from Vintage Air.
Thank you all for the advice and pictures. I know it will come in handy when I start the install.
