Diff ratios
Old Jul 12, 2014 | 08:59 PM
mrichi's Avatar
mrichi
Default Diff ratios
I have a 79 Auto Corvette , how can I find what diff ratio it has ? On the highway at around 65mph the motor is running over 3,000 -3,500 rpm
Are the diff ratio numbers stamped on the diff housing ?
Old Jul 12, 2014 | 09:17 PM
mrvette's Avatar
mrvette
NO way to tell without counting, I assume your have positraction, so both rear wheels are 'locked' to to put in neutral, SAFELY jack the rear tires off the ground, and chaulk the tires and the driveshaft....
spin the driveshaft and carefully count the rotations and final position while the tires turn just ONE complete rotation.....
so lets assume the tires do one rotation, and the drive shaft does 3.3 or so rotations, that means the gearset is 3.36.......
or say 4.1 rotations.....obviously a 4.11 rear.....
no rocket science....
Old Jul 12, 2014 | 10:03 PM
mrichi's Avatar
mrichi
thanks for that , just as well I'm not working at NASA lol
Old Jul 13, 2014 | 09:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Differentials are stamped with a code for the original ratio. Of course, gear sets could have been changed any time in the past.
To Diff ratios
