Need a little help here because I am not a mechanic. Can anyone tell me, will L82 valve covers fit on my L48 350 motor sb? By that I mean will the Four holes on the covers line up with the holes on the block? Trying to find out before I buy them.
No such thing, we all had to learn as we went along.
Exactly better safe than sorry, those L82 covers will cost you. Now, the bolts holding the covers down will be different, so make sure you pick up a set of those as well.
standard roller rockers will not fit, without modifications.
I rememeber when I tossed mine out, because roller rockers would not go under them.
all Small block orgnial 1st generation Chevy blocks use the same valve cover mounting.
