never do this again
Old Jul 28, 2014 | 06:28 PM
namvet6869's Avatar
namvet6869
Default never do this again
Got the bright idea I would take my tail lights out and give them a good cleaning on my 81. It took me over an hour to get them back in. Anyone know of a quick way to align the light guide pin with the body. I got the job done but many four letter words and comments to the corvette engineers.
Old Jul 28, 2014 | 08:07 PM
69Pman's Avatar
69Pman
You know, they say the C3s are the easiest to work on…
Old Jul 28, 2014 | 10:25 PM
Texas70's Avatar
Texas70
I actually think the design team were a bunch of sick SOB's that took joy in making the simplest task complicated. I cannot even begin to image the thought process that went into some things.
Old Jul 29, 2014 | 01:01 AM
Les's Avatar
Les
If you ever remove & replace the vacuum booster for the brakes you'll be convinced that the tail light assembly was designed by the A team.
Old Jul 29, 2014 | 05:04 AM
F22's Avatar
F22
I love how the stick shift plate has two to three inches of clearance behind the stick, but only a half inch in front of it. The stick hits the front edge unless you force the entire trans tunnel cover up against the center gauge stack. I gave up and now a split peice of 3/4 rubber hose cushions the plate against those moments when I'm really shifting hard. Go figure.
Old Jul 29, 2014 | 11:23 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Welcome to our world, namvet. I guess no one ever said any of this would be easy.
Old Jul 29, 2014 | 11:32 AM
MikeDs73's Avatar
MikeDs73
Reinstalling the Power Steering Pump (by yourself without a lift) is right up there on my list!
Old Jul 29, 2014 | 12:01 PM
Tooonz's Avatar
Tooonz
Removing it by your self isn't fun either, but now I know I'm in for a fun time reinstalling it
Old Jul 29, 2014 | 03:20 PM
dochorsepower's Avatar
dochorsepower
"If you ever remove & replace the vacuum booster for the brakes you'll be convinced that the tail light assembly was designed by the A team."
Amen!
Old Jul 29, 2014 | 07:31 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
And we thought 120F*plus with a bath every 30 days was the pits!
Stinking Politicians and Corvette Tail Light Engineers!
Old Jul 29, 2014 | 08:31 PM
rmm82's Avatar
rmm82
I'm pretty sure I know which was the initial part on the assembly line. It was the headlight switch hanging down from a string and they built the car around it!
Old Jul 29, 2014 | 09:06 PM
doorgunner's Avatar
doorgunner
Probably!
"How to reset the TPS (Tire Pressure Sensor) on a GM vehicle (per owner's manual): ......turn the headlight switch On and Off four times within three seconds.....then remove the driver-side valve cap from the wheel......"
Old Jul 29, 2014 | 10:13 PM
qwank's Avatar
qwank
I never have a problem with them. I even converted to 4 brake lamps and had to drill new holes for the inner lamps
Old Jul 30, 2014 | 07:52 AM
minitech's Avatar
minitech
Originally Posted by doorgunner
Probably!
Yes in later years the engineers didn't get much more forward thinking for the owners and maintenance later sometimes:
My Cadillac STS 2005 headlight change:
1. Jack the front of the car up
2. Remove both front tires
3. Remove both inner fender wells
4. Unbolt and remove front bumper from the inside
5. Remove headlight assembly
6. Remove 4 screws from the panel on back of the assembly
7. Change headlight bulb.
8. Reverse procedure to complete.
Dealer time 3 hours.
Old Jul 30, 2014 | 08:01 AM
F22's Avatar
F22
I was just telling a coworker yesterday, that my next car is going to be a '63 Chevy Nova wagon, with a straight six, a 700r4 and AC. For the exact reason of what you went through on the Cad!
Old Jul 30, 2014 | 09:19 AM
qwank's Avatar
qwank
i want to work at the dealer that gets 3 hours to change those bulbs. we get an hour here if we have to remove the bumper, 0.3 if we don't
Old Jul 30, 2014 | 07:50 PM
minitech's Avatar
minitech
I was going to do it myself, all small tasks and possible at home but I would trade half a weekend day for it. Dealer said it was ridiculous that it costs so much to change it and did me the favor of changing the bulb for $90. I forgot to have him replace the other one though while he was there!
To never do this again
