76 tach problem
Old Aug 2, 2014 | 01:23 AM
BARRY L-48's Avatar
BARRY L-48
Default 76 tach problem
the tach on my 76 just started to act up,when I am at idle the tach works fine,but when I drive it constantly fluctuates,would, a filter solve this or do I have other issues with it?
Old Aug 2, 2014 | 01:30 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Barry.. bypass the filter and see if the issue continues.. If it does odd's are the board is the issue.
Info on your tach and board can be found at this link: \
http://willcoxcorvette.com/advanced_...&keywords=tach
To bypass the filter.. unplug (at A) the filter and plug the tach wire directly into the coil.
Willcox
Old Aug 2, 2014 | 11:27 AM
0Willcox Corvette
Former Vendor
I saw your other post about the filter.. adding one will not solve this problem.
pull the connector from the back of the tach and make sure the terminals are clean and making good contact. Do the same for the one at the distributor..
Make sure the wire from the distributor to the tach is in good working shape with no cuts or splices...
Test again. . . If you still have the problem th I'm guessing the board is the issue..
Willcox
Old Aug 2, 2014 | 03:40 PM
BARRY L-48's Avatar
BARRY L-48
ok and thanks for your help!
To 76 tach problem
