project 75 c3
Old Aug 3, 2014 | 11:59 AM
galippo's Avatar
galippo
Default project 75 c3
any suggestions I picked up a 75 vette project and engine runs pretty smooth, Im pulling engine and trans at same time to clean it up,
should i replace rear main seal while i got it out im doing oil pan
any other maintenence to engine or tranny
Old Aug 3, 2014 | 08:42 PM
marz's Avatar
marz
That would probably be a great idea since you have it out. It's better to work forward than backwards. I learned that on the 75 I used to have. If an auto tranny look at the flexplate for any broken or worn teeth. Are you keeping it original or any power adds for it? Post some pics and someone will see something you may need to address.
Congrats!
Old Aug 4, 2014 | 03:51 PM
dochorsepower's Avatar
dochorsepower
If you are pulling the oil pan, reinstall with a Fel-Pro one piece pan gasket set. It will solve most oil leak problems.
To project 75 c3
