rivoted rotors
Old Aug 6, 2014 | 05:56 PM
Kdoran11's Avatar
Kdoran11
1st Gear
Default rivoted rotors
Just got ready to do my rotors and found the are rivoted to th e spindle,
if I remove the rivots, do I need to rivot the new rotors to the spindles?
78 Pace Car
Old Aug 6, 2014 | 06:12 PM
Ironcross's Avatar
Ironcross
Originally Posted by Kdoran11
Just got ready to do my rotors and found the are rivoted tom the hub th e spindle,
78 Pace Car
No,
Easy way to separate the rotor from the hub `if you need rotors is to use a oversize drill bit and cut the tops of the rivets..Then use a drift to drive the rivets out......Next, drive the studs out to finish the separation hub from rotor......Just reverse the above procedure. The studs will hold the new rotors to the hubs.....You may still need to true up the rotors with a parts stores or machine shops rotor cutting machine.....
Old Aug 6, 2014 | 08:20 PM
pws69's Avatar
pws69
You don't need to "drive the studs out" - just the rivets after you drill the heads off. If you are reusing the rotors, mark a stud and a matching place on the rotor so you can put them back in the same place.
Old Aug 6, 2014 | 08:44 PM
SpartyGW's Avatar
SpartyGW
I went through this recently with my dad and his '81.
What was the engineering idea behind the rivets? What a pain in the butt!
Old Aug 7, 2014 | 05:54 AM
cvm's Avatar
cvm
Default st louis
to keep them in place going down the assembly line.
Some may argue as a centering anchor. many different bolts/screws used by various manuf. today
Old Aug 7, 2014 | 08:43 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you need to replace rotors? They seldom fail. The factory assemblies were riveted to the hubs to allow machining of the rotors for run out tolerances.
If you replace your rotors, you will need to mike for run out. Calipers will keep the rotors in place without rivets.
Old Aug 7, 2014 | 08:49 AM
71scgc's Avatar
71scgc
Measure the rotors. If they make spec, don't remove them.
Carter
Old Aug 7, 2014 | 10:50 AM
SpartyGW's Avatar
SpartyGW
Aha, interesting.
Thanks.
Old Aug 7, 2014 | 10:53 AM
Mike Ward's Avatar
Mike Ward
False
Correct.
Old Aug 7, 2014 | 12:10 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
if your gonna seperate them, mark them so they can return to their orginal hub and orientation.
cheap way of keeping the factory run out orginal,
Best to leave the fronts riveted. Rear must be removed for service.
Old Aug 7, 2014 | 04:23 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by 71scgc
...Measure the rotors. If they make spec, don't remove them...
To rivoted rotors
