Orphan plug on engine harness???
Old Aug 6, 2014 | 06:47 PM
Texas70's Avatar
Texas70
Default Orphan plug on engine harness???
Trying to get the engine compartment wired up and I have a plug that I cannot identify. I looked through all the photos I took and referenced the wiring diagram with no luck (maybe I am overlooking it).
It is a two prong plug, one orange wire and one black with purple tracer. The plug exits the harness near the wiper motor.
Any guesses?
Old Aug 6, 2014 | 07:14 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
what year?
Old Aug 6, 2014 | 07:39 PM
Crafty12's Avatar
Crafty12
Screen name is 70, so maybe a 70? It looks a bit like my 70. TCS gas pedal switch for an automatic says my wire diagram. If you have a stick it might not have anything to plug into. I found a few of those when I did mine.
Old Aug 6, 2014 | 09:22 PM
Texas70's Avatar
Texas70
It is a 1970 (mostly...LOL).
You are correct, it is the connector for the kick-down switch. I was just a little baffled on why it was on the engine side of the harness. I used the ohm meter and tracked it to the end that would be plugged into the transmission solenoid. It will get secured out of the way since I installed a manual during my rebuild.
Thanks to everyone that has looked into this.
Old Aug 6, 2014 | 11:15 PM
Raphiki's Avatar
Raphiki
Had the same on my mostly '70. Thought 70 might be birth year - there are some members that young!
Old Aug 6, 2014 | 11:40 PM
Texas70's Avatar
Texas70
LOL...birth year is 69, so it is real close.
To Orphan plug on engine harness???
