Engine/trans cockeyed
Aug 26, 2014 | 10:07 PM
Good suggestions guys. I'm going to check the seating of the mounts tomorrow. I'm hoping it's not the frame.
Sep 16, 2014 | 08:41 PM
So for those helping with suggestions and interested in progress, I found out that the frame was bent. The driver side front was pushed in which moved the motor mount in and up about 1 1/2 inches off.
To get the frame straightened I had to pull the engine.
Sep 16, 2014 | 08:44 PM
Last weekend the engine went back in.
Sep 16, 2014 | 08:47 PM
And that engine is perfectly level.
Sep 18, 2014 | 06:09 PM
Quote:
Originally Posted by
Sklaris
Sorry you had to go through all that. I was really hopping it would be something easy. Nice looking car.
Zorro
Sep 19, 2014 | 09:55 AM
I had the same issue with my 68 but at some point someone decided to remove and reweld drivers side frame engine mount??? so when i got the frame straightend i had to remove and reweld the drivers side engine mount on the frame what a total pita!!!! glad u got it fixed the right way!!!
Sep 19, 2014 | 11:18 AM
Looks like a tough fix but excellent job correcting the problem.
Sep 19, 2014 | 12:13 PM
Thanks guys. I guess this is just another right-of-passage with owning a Vette. I'm back to loving it again and now looking forward to finishing it.
Sep 19, 2014 | 02:04 PM
Glad you found the root cause and fixed it properly. Nice looking Vette, will be worth all the effort once you're out cruising the town.
