72 Automatic goes into reverse
Old Aug 15, 2014 | 12:46 PM
billyoung51's Avatar
billyoung51
1st Gear
Default 72 Automatic goes into reverse
I have a 72 Automatic that goes into revers without pushing the shift button down. What can I do to fix this.
Old Aug 15, 2014 | 02:12 PM
Mooser's Avatar
Mooser
The adjustment is down on the transmission where the cable attaches to the lever.
The lever has a slotted hole with a stud screwed into it that the cable goes onto. You'll need to loose the stud and adjust so the trans is in the same sector that the shifter detent is in.
Adjustment settings are in the AIM
The stud is the one with the cotter pin facing you in it in this picture
M
Old Aug 15, 2014 | 03:53 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There is also a detent tab on the shifter under the console. With age, the tab can break off or wear to the point the shifter slides right past it.
To 72 Automatic goes into reverse
