Horn help needed please
Let's clear up a couple things first that other members will need to know:
Do not remove the horn button yet---it may not be the problem--no sense in breaking the assembly for nothing.
Do you have a wiring diagram for your year?
You said "no horns".....does that mean there is NO SOUND coming from the two horns-------
------or does it mean that Bubba completely removed the two horns from the car?
Also.......have you checked the fuse.............
have you checked to see if the horn relay is getting the correct voltage when the horn button is depressed.
Are the wires actually plugged into the horns themselves.
Give other members time to wind down from their day's work----one of them will have the right info.
If you have the wiring diagram and the voltmeter.....check the correct wire that goes to the horn relay when the horn button is held down---if there is 12 volts---the system is O.K. from the horn button to the relay terminal.
Also connect a 12 volt positive jumper from a good under-hood source to the main wire than runs to the horns, themselves........if they blow---they are in good shape---if not--check the ground wire from the horns to the frame......if still no noise---connect a known good horn to the main wire and ground the good horn to test it with the 12 v jumper.
(On my '68 I disconnect the horn button wire acts as a ground wire from the relay. I disconnected it from the relay and tested it for continuity----the ohm needle should "peg-out" if the wire and horn assembly in the steering column are good when the button is pressed/I also installed a permanent flexible jumper wire across the steering "rag-joint" to make sure continuity wasn't being lost as the steering was turned (precautionary modification).
Anyone feel free to correct any wrong info!!!!!
Also I would check at the horn relay connector and see if you have 12 volts on the red wire. This wire should always have 12 volts on it, but it is good check it and make sure.
An alternate method of checking your horns would be, once you have verified 12 volts at the horn relay connector, is to jumper the red wire to the dark green wire. Use a piece of wire, or a paper clip, and insert in the horn relay connector to jumper the red and dark green wires. For God sakes don't jumper the red and black wires together as the bomb will go off.
In other words you will blow a fuse or the thermo wire from the alternator. If you do all this (check the black wire for ground, red wire for 12 volts, jumper the red and dark green wires) and the horns work, you have a bad relay. If not then, like doorgunner said, check the grounds at the horns.
http://www.hunt4cleanair.net/Article..._Diagnosis.pdf
Good luck
Good luck
This is the way to do it. Don't tear your steering column apart to find that your actual horn is dead (common) or that your relay needs to be replaced.
Good thinking!!!!!
Good luck
KO
