72 rebuilt power steering pump
Old Sep 5, 2014 | 08:36 AM
gearbreaker's Avatar
gearbreaker
Default 72 rebuilt power steering pump
my power steering pump is howling so I thought I would replace it.
ive never done this before but I figure its nuts and bolts and some fluid, it shouldnt be too hard.
I ordered a rebuilt pump online and got this (Cardone, fits 63-74).
this doesn't look like the pump on my 72. what am I supposed to do with this?
thanks for any help.
Old Sep 5, 2014 | 09:05 AM
AirborneSilva's Avatar
AirborneSilva
Can you post a picture of your original pump? what do you mean it doesn't look like that?
Old Sep 5, 2014 | 09:10 AM
Ironcross's Avatar
Ironcross
Will it fit?...
.if so use it or just change the reservoir....Simple operation....A-1 Caredone is a national brand sold at most parts stores.....
Old Sep 5, 2014 | 09:21 AM
gearbreaker
front of my pump (still on the car)
back of the pump. the return on my pump points to 5 o-clock. the return on the replacement pump points to 9 o-clock.
Old Sep 5, 2014 | 09:27 AM
AirborneSilva
Looks like it will fit to me, you just need to get a puller/installer for your pulley
Old Sep 5, 2014 | 09:58 AM
Ironcross's Avatar
Ironcross
Then remove the can from the old pump and place it on the new pump in the correct position ....no new left only rebuilts....
Old Sep 5, 2014 | 10:53 AM
Kevova's Avatar
Kevova
Patience and a manual is required. GM is notorious for a fastener that requires excssive effort to remove. A pulley puller/installer maybe rented from auto parts store. Pump may come with pulley install consisting of 3/8 bolt,washer,&nut. - not the best but will work. The reservoir or" Can" tends to get bent causing leaks because it gets pried on adjusting belt. In the "old days" the Can was a transfer part. Transfering the return hose to "can" is a PITA ...patiences. If you decide to try to transfer original "can" you will need seal kit every thru hole requires seal and it is somewhat fragile. tighting bolts to draw it on may bend "can" only FSM from any older gm some ford,chrys,amc, may have info concerning "Saginaw" P/S pump is seems they all used it at one time or another
Old Sep 5, 2014 | 11:15 AM
gearbreaker
thanks everyone for the help.
here's a couple pics of my pulley. does this pulley in fact need a puller or is it held on with the nuts? I don't see where a puller would grab on to the pulley.
the rebuilt pump shaft has a threaded end and a keyway.
Old Sep 5, 2014 | 11:20 AM
gearbreaker
hold on a sec.
what I think is an inner nut, isn't actually a nut but the flange on the pulley that a puller would grab ahold of.
am I correct?
Old Sep 5, 2014 | 11:25 AM
AirborneSilva
I'd say no, you don't need a puller/installer. It looks like it has a nut that holds it on and the inner part that looks like a nut is just a part of the pulley so you can use a wrench to tighten the nut against it (if that makes sense)...
Old Sep 5, 2014 | 11:28 AM
gearbreaker
that does make sense.
Old Sep 5, 2014 | 11:37 AM
AirborneSilva
git er done
By the way, I'm fighting power steering pump issues, I will soon be going on my third "rebuilt" pump. first one leaked, this one stopped working. I pulled the valve off the back to see what I could see (of course you really need to know what it is you're looking for), put it back together and it's working ok - for now
Old Sep 5, 2014 | 11:47 AM
gearbreaker
if mine gives me more headaches than I am willing to take, I may just switch it over to manual and take all the power components off.
ive owned cars in the past with manual steering and it wasn't the end of the world.
Old Sep 5, 2014 | 11:51 AM
AirborneSilva
Yeah I drove mine the other day when the pump wasn't pumping, it was as you said not the end of the world!
Old Sep 5, 2014 | 11:54 AM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
I changed mine out and I don't have a puller.
That pump body looks more like the older (C2?) pumps with that longer, round filler tube. Mine was an exact replacement, I got it from Lone Star Caliper.
Old Sep 5, 2014 | 06:00 PM
gearbreaker
I'm gonna return the one I got. that one from lone star looks much better to me. thanks for the info.
Old Sep 5, 2014 | 06:52 PM
Haggisbash's Avatar
Haggisbash
Hi as Airborne said the second "nut" on the pulley is there so you can tighten the outside one. You may get lucky as I did and once the nut was off the pulley came off without a puller. Some pump pulleys had holes in them that allowed you to get at the mounting bolt behind the pulley so that you could remove it and take the pump out with the pulley still attached, not sure what year they started to do this though. FWIW I think it is a bit of a gamble getting any of the so called rebuilt pumps as they usually seem to just have new seals, maybe a reservoir and a paint job. You are entirely at the mercy of the re-builder as to how good the core was before rebuild. I got one and within no time it started to moan just like the original one:-( I have one on order from a supplier who grinds the case of the pump and fits new vanes etc and it seems that the number of suppliers who do this are the same as unicorns have horns:-)
To 72 rebuilt power steering pump
