Emergency Brake
Old Sep 11, 2014 | 07:49 AM
rrkriete's Avatar
rrkriete
3rd Gear
Default Emergency Brake
I have a '78 that I bought new and over the years the emergency brake has become almost useless. I have heard that there is an aftermarket fix for this that takes up slack in the cable. Can anyone shed more light on this subject; like where to buy it and the degree of difficulty to install it?
Thank you,
Richard
Old Sep 11, 2014 | 08:17 AM
F22's Avatar
F22
Thank you,
Richard
The only fix, I'm aware of, is fixing it. You can adjust the parking brake cable, by safely jacking up the car, putting it on jack stands and getting underneath the vehicle. If you've reached the end of the cable adjustment, you'll have to adjust the parking brakes themselves. The adjustment is done with a screwdriver, through a hole in the outer edge, of the center of each rear brake rotor. Or you may have to rebuild them. You should have the FSM or Factory Service Manual as as guide to do this, as it's not exactly a simple job. If in doubt, take it to a mechanic or have somebody proficient he'll you out.
Old Sep 11, 2014 | 08:49 AM
mk's78's Avatar
mk's78
Just had had my 78's rear trailing arms etc replaced because the PO had the parking brake assy disconnected with the shoes and holding pins removed....After all is said and done and after having the PB adjusted several times by my certified NCRS expert the story is that the PB assy never did completely hold the car from the factory...It was a bad GM design and even after all the work is done it still won't hold the car.....Just my .02 cents worth...mk's 78 Mike
Good luck.........
To Emergency Brake
