I put a set of Corbeau A4's in mine. You have to get the narrow option as the wides won't fit and get the shaved lower section so you have alittle more head room. I also mounted them to the floor as they wouldn't tilt fowardwhile on the sliders. The above comments were the ones that worked for me. Your interior may be different.
Reason: spelling
I went w/ the GTS II. Fit nice- but felt the headrest looked out of place and too tall so I cut them down.
The brackets are too tall as well- and working on modding the GM factory ones to get them closer to the floor. I believe Speed Direct sells a set that is already cut down on the bottom cushion to help.
Several threads in here about seats... I just had mine rebuilt and new padding,bolsters for thighs and sides added....Perforated center panel.. Bolted right back in since they are the original frames....
