82 coll vette
Old Sep 11, 2014 | 12:48 PM
spotzie's Avatar
spotzie
Default 82 coll vette
I got my answer to dash plate question...called Paragon Corvette...1 800 882-4688...spoke with Blane (sp) and he was very helpful. They cover 1956-1982 Vettes...my be helpful to some of you. I ordered my catalog today. Thanks
Old Sep 11, 2014 | 02:06 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by spotzie
...I got my answer to dash plate question...
Good. What was the question?
Old Sep 12, 2014 | 01:31 PM
spotzie's Avatar
spotzie
thank you very much for responding. I posted a question about the removal of the faceplate that covers my radio and gauges in my dashboard. I learned the answer from Paragon Corvettes. I also learned by trial and struggle about the upper light housing that adds to the fun of removing the faceplate....luckily I protected everything in the process and took my time...it all came out fine and no damage so far. I had to remove the radio to find out if my radio isn't working correctly or if its my antenna. I just had my motorized antenna rebuilt and now my radio won't tune in any am or fm stations. It was suggested in this forum that I remove the radio....sounded easy enough....and disconnect the antenna from it and see what happens. Sorry to report no change. Now I am plugging in a new antenna and checking to see if that makes any difference. Wish me luck. If you know of any other tests I can try please let me know. Thanks
Old Sep 12, 2014 | 09:41 PM
vettebuyer6369's Avatar
vettebuyer6369
Suggestion: use different titles for different threads about different subjects. If they all say "82 coll vette" no one can find them and they might get deleted as dupes.
Old Sep 12, 2014 | 10:21 PM
spotzie's Avatar
spotzie
thank you for that suggestion....I am new to this and am still learning how to do this forum communication.
Old Sep 12, 2014 | 10:41 PM
spotzie's Avatar
spotzie
I tried to put a new antenna in my radio of my 82 col vette and it didn't fit. I know my radio has a digital or led read out on the front but is it a digital radio or analog? The history of all of this is... I recently had my power antenna rebuilt because I couldn't find any original replacement parts for it. Now my antenna goes up when the radio is on and down when off like it should but my radio will not seek/scan or tune in any am or fm stations. That is why in following another forum persons suggestion I took of the faceplate off my radio so I could remove the radio and disconnect the antenna to test if it was the problem. I removed the antenna from the radio and it made no difference. That is why I an asking above about my radio being analog or digital. I believe it is the original am/fm/casette/cb radio. The antenna I bought today is supposed to be universal but it would not fit. It was to big. Do you know of some other way than doing the test I did, removing the antenna wire or trying a different antenna, that unfortunately didn't fit, that I can be certain what the problem is and possibly fix it? Please let me know. Thanks
Old Sep 12, 2014 | 10:45 PM
qwank's Avatar
qwank
Does the cassette player work?
Old Sep 13, 2014 | 11:17 AM
spotzie's Avatar
spotzie
yes....but I can not manually tune in any am/fm channels or change the channel using seek or scan....plus the cb doesn't work either. Got any ideas of what is wrong?
To 82 coll vette
