1976 Tach help
Old Sep 13, 2014 | 11:25 AM
72and86's Avatar
72and86
Default 1976 Tach help
Ok… continuing my 76 restore. (I fix 1 thing, 2 things break…)
All of a sudden my tach shows 2500 no matter what, even off. Is the 1976 an electrical tach or mechanical?
With the center gauges out I tried to look in back of the driver's dash pad but the AC duct (or something) makes it impossible..
I don't see anything hanging or lose on the distributor…
Any idea where to start to fix this?
Old Sep 13, 2014 | 11:41 AM
F22's Avatar
F22
I can't claim to know when the C3 went to an electric tach, but I can tell you, that the mechanical is driven off of the bottom of the distributor shaft, right below the cap, but before it goes down into the intake. It is on the drivers side and enters the dash area through a hole in the firewall.
If it's a mech tach, you'll see a thick black cable, about the diameter of your pinky, running through the area I just described. You can unscrew it from the distributor using these gnurled ring, but beware, do not lose the little brass insert that goes in the hole and on the end of the cable!
Now that you have the cable in your hand, you can check to see if it spins freely. You also shouldn't be able to pull it out either, as the other end is locked with a clip into the back of the tach. Assuming it it spins freely, have somebody watch the tach, while you twirl it. You should see the needle move . If you don't, you might have problems with tach or the other end of the cable.
Old Sep 13, 2014 | 03:20 PM
20mercury's Avatar
20mercury
Default My 2 cents...
Electronic tach came with the HEI distributor (no points) starting in 1975. If you have an original setup with HEI, which is likely I would guess, then you have a electronic tach. On my 76, the electronic tach went out, so I had to pull the dash and replace the "tach circuit board" behind the tach. Good to replace the tach board and the filter at the same time. The filter is a small cylinder (think it is a condenser) mounted on the intake right next to the carb. The tach boards for these years are not too good, so I would bet yours just went bad. Wilcox has a nice write up on this in his tech papers (thanks!) hope this might help.
Oh can relate to the 1 step forward and 2 back days, but this forum is great and much thanks to all.
Old Sep 13, 2014 | 04:52 PM
F22's Avatar
F22
Thanks for chiming in! I have a '74 and now I know, cool and yes, this forum is great!!!
Old Sep 13, 2014 | 08:12 PM
LS4 PILOT's Avatar
LS4 PILOT
I had TWO electronic tach die on my L82 79 vette and it was only a couple years old ....both died as you described .
I personally trust the cable driven tach deal in my 74 more. 27 years no issue.
Old Sep 14, 2014 | 12:24 AM
bradleyb66's Avatar
bradleyb66
I just repaired the elec tach in my 79 (this weekend actually), but the symptom sounds different. Mine would read 0 RPM with the car off, but would redline as soon as the engine started. I found some info on a resistor that goes bad on the circuit board, so I replaced it with a potentiometer (variable resistor), verified that it functions normally now, and will be calibrating it tomorrow (didn't have time to dig out a stand-alone tach to synchronize it to).
If I didn't already have the parts on hand, I would have probably just bought the whole board from Willcox (An A#1 vendor in my book!)
Old Sep 14, 2014 | 09:47 AM
palmbeachvette76's Avatar
palmbeachvette76
All you need is the tach circuit board but most importantly, order the correct one for your year and make sure it states to already be Calibrated. Several vendors sell a board that isn't calibrated and won't work and with as much fun is involved with installing this you want to get it right the first time. I had to do the job twice since I didn't know about the calibrated versus non-calibrated until afterwards. This was several years ago so maybe they are all correct now but just wanted to let you know. Mine still works fine.
Eric
Old Sep 21, 2014 | 12:38 AM
72and86's Avatar
72and86
Turns out it was a "Gauges" fuse blown. I didn't know it was fused. Anyway: free fix.
To 1976 Tach help
