Still having trouble
But at any rate here is my adventure shortly after buying mine. Slightly different because mine is a 74, however it fits what you are doing.
I was able to use the factory plug shown by Wilcox that was in the car. I just used a wiring terminal to (plug in) each wire. (for now)
Sending unit wire (I chose to run a new one for the time being) power wire was good.
The ground I ran to the back of the gauge cluster.
That would be the first suspect for me in your case. Used to do it a lot, now I can't remember if grounding the gauge will spike it max, or low. But the ground will make a big difference.
Yes you do not need the resistor on the out side of the gauge.
Where did you put the sending unit?
I did have to bend the connection down (90 degrees) on mine to plug it in. But like the one pictured it is in the same spot.
At any rate here is my thread.
https://www.corvetteforum.com/forums...g-adapter.html
This is what I have been doing for several years. Now on the newer fancy stuff.
It gets interesting when you are looking for a part, or just trying to figure out how the wires are routed.
How did you wire the gauge?
Sending unit to one post, 12v to the other, ground to the 3rd?
If not that is your problem.
Look at the diagram Wilcox posted in my thread.
