68 temp unit ???
Old Oct 10, 2014 | 09:02 AM
go bucks's Avatar
go bucks
Default 68 temp unit ???
Where is the temp. sending unit on a 68 Big block?
Jack
Old Oct 10, 2014 | 09:51 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Jack,
drivers side of block about 2-3 spark plugs back.
Should have a single wire to it from the alternator loom.
Read recent posts on these senders before purchasing a replacement.
Apparently calibration is off on new ones so guage won't read correct temp.
Marshal
Old Oct 13, 2014 | 07:13 PM
go bucks's Avatar
go bucks
Thanks Marshal.
For some reason I can't seem to locate it on this block. I figured it was where you said, but it just doesn't make sense. There is obviously not a lot of room with the spark plug and original exhaust manifold.......could you be a bit more s pacific please?
Old Oct 13, 2014 | 07:36 PM
shmoky's Avatar
shmoky
This is where it is on my BB.
shmoky
Old Oct 14, 2014 | 01:35 PM
69MA's Avatar
69MA
The sending unit is not on the block it is on the head (same area where you were looking). I have also seen them on the intake manifold near the radiator hose.
To 68 temp unit ???
