Should early 68 convertible top latches have the black rubber grips on the handles or not? Reason I ask is I received 2 with the grip and one without and need to return .....something!
thanks in advance
Most of the 68 run had chrome latches. No rubber. FYI my original to my car hardtop ( May 68 ) has chrome latches as well.
thanks in advance
My 68 Convertible has all chrome only latch handles. The 70 Coupe has black rubber grips.
I re-chromed the 70 latches. Pull the latch down, and use an Xacto blade to cut a line on the non-flat side of the latch handle...the rubber coating slips right off. After chroming, you can slide it back on and no one will notice.
