^79 seat angle
Old Oct 12, 2014 | 08:32 PM
jwappes's Avatar
jwappes
Default ^79 seat angle
Does anyone know how to adjust the angle on the back of the seat on a 1979 corvette?
Old Oct 12, 2014 | 09:34 PM
qwank's Avatar
qwank
you don't
Old Oct 12, 2014 | 09:55 PM
gjohnson's Avatar
gjohnson
Some have suggested slicing rubber tubing in half and fitting it over the clamshell edge acting as a bumper that will slightly tilt the top half forward depending on the size of the tubing used.
Old Oct 12, 2014 | 11:28 PM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
Supposedly there was an adapter the dealer could install to bring the seat back up a bit, but I don't know the exact details.
Old Oct 13, 2014 | 08:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Rky Mtn C6
...Supposedly there was an adapter the dealer could install to bring the seat back up a bit, but I don't know the exact details...
The 68-78 straight back buckets could be shimmed for angle adjustment, but the clamshell seats cannot.
Try shimming under the rear seat feet.
Old Oct 14, 2014 | 12:59 AM
SciVette's Avatar
SciVette
That's what I've done with my '80. Multiple layers of slit heater hose to raise the seat back from the reclining "rocket launch" position... The hose provides a bit of give and is hardly noticeable unless the seat back is folded down.
Old Oct 15, 2014 | 07:21 PM
John A F's Avatar
John A F
I put a stack of 4 washers under each side at the rear seat tracks between the track and the floor. That 1/2 inch under the seat track made a big difference in the angle of the seat back.
Old Oct 15, 2014 | 07:52 PM
jwappes's Avatar
jwappes
Default washers
Washers sound like the best way to go. If 4 washers is not enough I can try the rubber hose trick. Thanks, John
To ^79 seat angle
