Headlight question
Old Oct 27, 2014 | 11:51 AM
TO_Vette's Avatar
TO_Vette
Default Headlight question
On the C3 you can turn the headlights on without opening them, that is keeping them in the down position while they are on.
Is there any reason or application for this feature?
Old Oct 27, 2014 | 12:07 PM
Mike Ward's Avatar
Mike Ward
There is no such feature. Your car must have leaky vacuum system.
Old Oct 27, 2014 | 12:25 PM
TO_Vette's Avatar
TO_Vette
Sorry, maybe my question wasn't as clear as it could have been. There is a button below the steering wheel that controls the vacuum that will keep the lights in a down position with the lights on.
Also, I often see pictures of C3's that have the lights in a down position but the lights on which push some light through the grill. Other then being for dramatic effect is there any reason for this?
Old Oct 27, 2014 | 12:28 PM
Mike Ward's Avatar
Mike Ward
The valve below the steering wheel is to raise the lights without having to turn them on, the opposite of what you're seeing.
No Corvette came from the factory operating in the manner you describe.
Old Oct 27, 2014 | 12:31 PM
Revi's Avatar
Revi
The only way for the headlights to be on, but the buckets to be down is if their isn't any vaccum to raise the buckets. Either the car is off (not running) and/or you have a vacuum leak.
Old Oct 27, 2014 | 12:35 PM
TO_Vette's Avatar
TO_Vette
No sorry, I guess i'm not getting my question across clearly. My lights and buckets work great, no problems at all, knock on wood. My question is purely for curiosity.
Is there a reason or application to have lights on with the buckets down?
Old Oct 27, 2014 | 01:11 PM
Walt71's Avatar
Walt71
Maybe it's so if you are trapped under the hood, you'll be able to find the release cable?
Old Oct 27, 2014 | 01:24 PM
Denpo's Avatar
Denpo
No Disrespect, but we did understand you, it's rather you who don't read the answers.
The **** you're talking about don't have the function you assume, or, actually have the complete opposite function.
Its function is to raise the headlight even if the light are off and the engine is not running.
It's currently working in this (wrong) way in you car probably because your vacuum setup has leaks.
Old Oct 27, 2014 | 02:28 PM
imariver's Avatar
imariver
On my 73, if I pulled the headlight switch out to the first position, the parking lights come on and no headlights, (no headlights on and the buckets don't come up) when I pull the headlight switch out to the second position, (or all the way out) the headlights will come on and the buckets will open. All this with the motor running. If the motor is not running, the only thing that changes is the buckets won't come up cause there's no vacuum.
I assume that this is the way they're suppose to function.
Old Oct 27, 2014 | 02:44 PM
Mike Ward's Avatar
Mike Ward
This is a sign of a vacuum leak. There should be enough residual vacuum in the system to raise/lower the headlights at least once for up to 24 hours or so after the engine is shutdown. This is how the cars were when new.
Old Oct 27, 2014 | 03:00 PM
C3Hawk's Avatar
C3Hawk
The short answer is: No!
The headlight switch is a dual function switch, meaning it controls both the electric circuit and vacuum routing at the same time. If you pull the headlight **** fully out, the lights should come on (as yours do) and the the buckets should come up if the vacuum system is working correctly (yours is not.)
As pointed out in the previous posts, in the interest of safety, the "fail-safe" position in case of vacuum leakage in the relay circuit was for the buckets to stay in the up position.
Old Oct 27, 2014 | 03:23 PM
AirborneSilva's Avatar
AirborneSilva
Now that's funny
Old Oct 27, 2014 | 04:26 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Other then being for dramatic effect is there any reason for this?...
No.
To Headlight question
