Storage question
Old Oct 28, 2014 | 09:42 AM
robbie shirkowski's Avatar
robbie shirkowski
Default Storage question
It's that time of year for a lot of us. I have always stored the corvette in a garage separate from the everyday drivers. However,this year I think I will store the vette in the same garage as the everyday cars. Question is with all of the snow and slush will it hurt the vette? I am worried about the dampness rusting the frame and some of the electrical connections. The garage is heated. Thanks
Old Oct 28, 2014 | 10:56 AM
Dodosmike's Avatar
Dodosmike
I just moved mine from warm storage to cold storage for this winter.
Is your garage warm enough to keep the floor/cars dry? I think your going to be fine.
Ive stored mine (heated) for 9 years in a row with no noticeable change in the original frame "rust" since I bought it.
dodosmike
Old Nov 1, 2014 | 12:00 AM
jhudec's Avatar
jhudec
I put mine in a car bubble. I am in northern ohio, attached garage, but not heated. I only fire up the heater when I need to do some work out there.
The car bubble circulates air through the vehicle, without it I would have condensation on everything, then rust.
Old Nov 1, 2014 | 09:36 AM
AkrHack's Avatar
AkrHack
I wonder just how much more humidity there really is in the winter with the presence of melting snow/slush compared to a humid and rainy summer day. If it is worse in the winter I may consider a bubble like jhudec uses to prevent an acceleration in frame rust.
I'd really like to hear from other members in the northern climates who keep their cars in unheated garages over the winter without encasing it in a bubble. Have you noticed an increase in frame rust from year to year?
Old Nov 1, 2014 | 09:51 AM
jhudec's Avatar
jhudec
It is the humidity/dampness combined with the cold temperatures creates condensation. This does not occur in the summer when it is even more humid because it stays warm. I had used a car bag before that you zipped the car into and you then place moisture absorbing bags inside, worked well, but the bubble is better. I picked mine up from a forum member who no longer needed it.
Just a bit more info.
Joe
Old Nov 1, 2014 | 10:17 AM
Mike Ward's Avatar
Mike Ward
There is no condensation or rust if the storage place is kept below the dew point. It's opening the garage door on warmer days that causes problems. The air inside the bubble is the same relative humidity as outside.............
Old Nov 1, 2014 | 10:27 AM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
I live in SW Pa. and keep mine in a dry, unheated, detached garage and my brake rotors don't even get rusty.
Old Nov 1, 2014 | 12:09 PM
71scgc's Avatar
71scgc
The wild swings in temp. is what results in condensation, winter or summer.
M. Ward is right...
Carter
Old Nov 1, 2014 | 12:30 PM
AkrHack's Avatar
AkrHack
M. Ward is right...
Carter
It sounds like more than one person feels that the swings in temperature is the cause for condensation. The OP's garage is heated. Perhaps that will lessen the extreme variations in temperature and therefore reduce the condensation.
Old Nov 1, 2014 | 12:55 PM
Mike Ward's Avatar
Mike Ward
The physics behind it is no more mysterious than condensation on a cold can of beer on a warm summer day.
Old Nov 1, 2014 | 01:55 PM
briankeery's Avatar
briankeery
Cold can of beer on a warm summer day would be pretty good about now.........
Old Nov 1, 2014 | 02:05 PM
Mick71's Avatar
Mick71
Hot chocolate by the fire maybe?
Old Nov 1, 2014 | 09:26 PM
Dodosmike's Avatar
Dodosmike
...hey!.......
Dodosmike
Old Nov 1, 2014 | 09:29 PM
briankeery's Avatar
briankeery
Didn't have my camera handy..........luckily your yard looked IDENTICAL to mine.....FFS!!!! Plus I had to take her to storage today.
To Storage question
