Should I dump the exhaust?
Old Oct 31, 2014 | 09:27 AM
Blak77's Avatar
Blak77
Default Should I dump the exhaust?
Hey guys I just put a set of 1-5/8" to 3" long tube headers on my 77 and I was going to have 2 1/2" pipe ran back to where the stock mufflers originally hung. Now I'm kinda thinking of hanging both mufflers around where the catylitic converter use to hang and turning them down right there. Has anybody done this? I'm a little concerned about resonance in the cab thanks in advance
Old Oct 31, 2014 | 10:28 AM
JimLentz's Avatar
JimLentz
I wouldn't do it for safety reasons.
Old Oct 31, 2014 | 10:31 AM
Blak77's Avatar
Blak77
Safety of what?
Old Oct 31, 2014 | 10:37 AM
JimLentz's Avatar
JimLentz
You could get exhaust gasses in the car.
Old Oct 31, 2014 | 10:43 AM
Blak77's Avatar
Blak77
Do you mean exhaust fumes?
Old Oct 31, 2014 | 10:44 AM
Blak77's Avatar
Blak77
Whoops I meant to send that before your last reply. Thank you for your input.
Old Oct 31, 2014 | 10:46 AM
73C34me's Avatar
73C34me
it will grow old on any drive that last more than a few minutes. & it is a little "low-brow" for a corvette, IMHO.
Old Oct 31, 2014 | 11:03 AM
tektrans's Avatar
tektrans
Dump it right before the rear wheels. As for exhaust gas in the car-how many drive around with the windows open with sidepipes?
Old Oct 31, 2014 | 11:14 AM
qwank's Avatar
qwank
I think you'll find there isn't enough room for two mufflers in that location
Old Oct 31, 2014 | 11:15 AM
Blak77's Avatar
Blak77
Thanks for the responses guys
Old Oct 31, 2014 | 11:32 AM
Gordonm's Avatar
Gordonm
There isn't any room for any kind of decent muffler and as said above the fumes will be to much at a stop light. Have a good system built and exit it in the stock location.
Old Oct 31, 2014 | 11:14 PM
C3 Stroker's Avatar
C3 Stroker
Also, you could get in trouble with the law, it's illegal to terminate exhaust under the car here......it must exit either the rear or the side of the car.
Old Nov 1, 2014 | 06:25 AM
tektrans's Avatar
tektrans
I made this up-it was pretty easy. I suppose you could exit it out the side if you wanted.
I had side pipes before and I hated the fumes so I put some high flow cats on.
Had to shape the floorboards a little bit to keep the heat off of them.
Old Nov 1, 2014 | 04:54 PM
Blak77's Avatar
Blak77
Awesome! Thanks for all the pics too, that really helps
Old Nov 2, 2014 | 09:17 PM
tektrans's Avatar
tektrans
Pleasure.
Old Nov 4, 2014 | 12:45 AM
Strokemyaxe's Avatar
Strokemyaxe
What is going on with those fans? Why are they there?
Old Nov 4, 2014 | 02:46 PM
tektrans's Avatar
tektrans
Those are my Trans coolers. I run an 8" converter cause I drag race, which builds alot of heat.
To Should I dump the exhaust?
