tire upgrade
Old Nov 2, 2014 | 12:52 PM
DICKAROO's Avatar
DICKAROO
Cruising
Default tire upgrade
My 1973 corvette needs new tires. I am considering going to a plus size p255/60r15 on stock 8in rally wheels. Will that be any problem without making modifications of any kind.
Old Nov 2, 2014 | 11:51 PM
3JsVette's Avatar
3JsVette
In '78 that size became an option. In the rear there are no issues. In the front there could be. The factory shaved the front edge and rear corner of the front fenders so there would be no tire rub. Look at any '78 Pace Car to see what I'm talking about. There are many C3s running this combination but there is no guarantee that they will fit on your car without rubbing. You need to "test fit" to be sure. I doubt that's the answer you want to hear but that's better than a cracked fender.
Old Nov 3, 2014 | 08:22 AM
DICKAROO's Avatar
DICKAROO
Cruising
thanks for your advice.
Old Nov 3, 2014 | 09:56 AM
Ontario73's Avatar
Ontario73
I'm running 255/60-15 BFGs on my 73 with stock wheels. The ONLY issue is a very slight rub on the driver's side frame when turned to the left at lock. An I put the emphasis on slight; just enough to polish the frame paint and I hit the lock position backing out of my driveway every trip.
Old Nov 3, 2014 | 09:59 AM
69FASTFUN's Avatar
69FASTFUN
I have never had any issues with 255 60 15 on any C3 that I have owned and I usually put BF Goodrich TA's on.
Old Nov 3, 2014 | 08:26 PM
gcusmano74's Avatar
gcusmano74
Only that the very wide tires may "tramline" along any ruts in the road.
IMHO (based on my experience on the lousy streets we have here in New Jersey), the 225/70 or 235/60 tires ride better and have a nicer steering feel.
Old Nov 3, 2014 | 09:54 PM
trw's Avatar
trw
I have 245x60 on the front and 255x60 on the rear.
Hope it helps.
Old Nov 3, 2014 | 10:41 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
A couple things for you to consider:
For the sake of being able to rotate the daily driver tires every year, I just installed PepBoy 235/70R-15 tires on 8" rims.
The tires were inexpensive---I didn't want to put quality tires on the front of my project until I was sure that I had all the front and rear alignment "bugs" taken care of.
I also wanted to lower the highway-RPM of the engine by going with larger diameter tires. There is about 1 1/2 inches of cleatance between the fender lip and the top of the tire when the car is lowered to the ground (the wheel really FILLS the wheel well!)
Once the car is painted and ready for long road-trips, I will put BFG RWL tires on the car (I will reconsider the tire size at that time)
(I think I will take a razor and shave the Futura GLS off the tires.....LOL!)
To tire upgrade
