How do I get wing off?
Old Nov 10, 2014 | 08:27 AM
SDS Photography's Avatar
SDS Photography
Default How do I get wing off?
Car has a wing on the rear deck. Yesterday I thought that I would just crawl under the car, contort my arm through the rear of the car, and take the bolt out. All that went fine until the last part where the bolt turns but does not back away from the wing. Any ideas?
EDIT - while I am asking, should those rear vents on top be black?
Old Nov 10, 2014 | 08:34 AM
Eljay's Avatar
Eljay
Sawzall
Old Nov 10, 2014 | 09:04 AM
SDS Photography
Believe me - if I had a sawzall the wing would be gone.
Old Nov 10, 2014 | 09:34 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by SDS Photography
...while I am asking, should those rear vents on top be black?...
Nope. Body color. The area beneth the vent grilles got black out treatment.
Old Nov 10, 2014 | 09:39 AM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Sounds like the threads are stripped in the pedastal on that last bolt. Have an assistant pull up on the pedastal from above while you turn the bolt from underneath.
The deck vents are usually body colored.
Old Nov 10, 2014 | 09:45 AM
SDS Photography
Ok, thanks.
Originally Posted by Mako72
Sounds like the threads are stripped in the pedastal on that last bolt. Have an assistanr pull up on the pedastal from above while you turn the bolt from underneath.
I tried that, but I am not sure how hard he was pulling. We were a bit worried about damaging the body. Will try again.
Old Nov 10, 2014 | 08:45 PM
gator79's Avatar
gator79
get a friend to pull upward on the wing while turning the bolt, put a little pressure on it, whatever it takes get that ricer wing off of that car.
Old Nov 10, 2014 | 09:48 PM
PeteL46's Avatar
PeteL46
If you cut it off you'll probably have access to the nuts/bolts. If using a sawsall be carefull; they can vibrate and bounce pretty good.. bottom the shoe on the leg, turn it on and slowly engage the blade into the leg. Maybe ise a jig saw, a lot more control.
Old Nov 11, 2014 | 06:04 PM
AdamMeh's Avatar
AdamMeh
I would saw through the legs of the wing low enough to get to the bolts inside it.
To How do I get wing off?
