72 Tire size help
Old Nov 25, 2014 | 10:25 PM
flyinrazrback's Avatar
flyinrazrback
Default 72 Tire size help
Getting ready for some black Friday tire specials. Currently have cheap Primewell 235/60r15 all the way around. I don't have a lot of room in back (see pic). Based on what you see will a 245/60 fit in back?
Old Nov 26, 2014 | 12:10 PM
MelWff's Avatar
MelWff
you are increasing section width by 10mm, 1 inch is 25.4mm so you are increasing width less than 1/2" divided by 2 means the sidewall will be less than a 1/4" closer to the spring.
Old Nov 26, 2014 | 12:44 PM
flyinrazrback
Thanks, I ended up just going back with the 235/60s since I know they fit.
Old Nov 26, 2014 | 01:35 PM
Gordonm's Avatar
Gordonm
On the rear a 255 60 15 will easily fit. You have plenty of room back there. I am running 275 40 18 with no issue.
To 72 Tire size help
