Rebuilding c3 calipers
Old Nov 30, 2014 | 05:51 PM
C3s4me's Avatar
C3s4me
Default Rebuilding c3 calipers
It seems like a pretty straight forward process to rebuild my C3 calipers. Although this will be my first attempt. These calipers are the original calipers that came with the car and have been rebuilt in the passed I was told. The previous owner had them sleeved already.... Any pointers before I attempt this? ( Lip seals or o-rings, etc.) Only one was leaking but all have been sitting since 98....I plan on re sealing all....thank, r
Old Nov 30, 2014 | 05:58 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Here, this outta shorten up the thread
Old Nov 30, 2014 | 06:00 PM
C3s4me's Avatar
C3s4me
Originally Posted by Hammerhead Fred
Thanks, I have already watch this one... thanks again, R
Old Nov 30, 2014 | 06:09 PM
SIXFOOTER's Avatar
SIXFOOTER
I like the O-Ring seals, don't seem to have as many problems with thenm.
Use compressed air to blow the pistons out of the calipers once you have them split, keep a rag over the piston and hold it there and just Pop the ait instead of blasting it, wear glasses and gloves. Clean them up, use fine crocus cloth to polish the sleeves. Put a little vaseline on the o-rings when reassembling.
Pretty easy job.
Old Nov 30, 2014 | 06:12 PM
briankeery's Avatar
briankeery
Pretty easy job.
I'd use brake fluid as my lubricant, but certainly not a deal breaker. Replace the rubber lines while you're in there, they're cheap. Also get a motive power bleeder, good investment as you'll use it every 2-3 years to flush the system.
Old Nov 30, 2014 | 06:43 PM
68/70Vette's Avatar
68/70Vette
Don't mean to be a spoil sport. I've replaced my Delco's with Stainless Steel Brake Corporation aluminum calipers. They are half the weight of Delco's. On the 68 and 70. Pricey. I think Wilwoods are less expensive. Not NCRS however. Hate brake caliper corrosion...silicon in the 68..stone hard pedal.
Old Nov 30, 2014 | 06:57 PM
72LS1Vette's Avatar
72LS1Vette
IMO, spend the extra $ for the O-ring rebuild kit. Leave out the springs.
I rebuilt my calipers with lip seals, drove it a little and then dismantled the car. When I put the calipers back on they leaked. After the O-ring rebuild I have driven the car for 4 years without any leaks.
Rick B.
Old Nov 30, 2014 | 07:16 PM
C3s4me's Avatar
C3s4me
Rick B.
Leave out the springs? Are they just not needed? Also best brake fluid for old c3 69 w/ stock calipers?
Old Nov 30, 2014 | 07:18 PM
C3s4me's Avatar
C3s4me
Thanks, I agree... I already bought a DIY bleeder similar to the Motive and special master cylinder cap to power/pressure bleed the system.. This I know is a must.....
Old Dec 1, 2014 | 11:45 AM
C3s4me's Avatar
C3s4me
Default Dot 3 /4 silicon brake fluid best for old original calipers?
Old Dec 1, 2014 | 01:07 PM
Mike Ward's Avatar
Mike Ward
No such thing.
If you've actually watched the video I posted and still want to use o-rings- oh well.
Old Dec 1, 2014 | 01:59 PM
Paul L's Avatar
Paul L
Sorry Sixfooter but Vaseline attacks rubber. Just use brake fluid.
Old Dec 1, 2014 | 03:50 PM
C3s4me's Avatar
C3s4me
Originally Posted by Mike Ward
No such thing.
Sorry,my mistake...I should have been more clear...dot3/4 synthetic or silicone...And I haven't said whether I am using lip seal or orings....thx for your time...r
Old Dec 1, 2014 | 03:52 PM
C3s4me's Avatar
C3s4me
Thanks for your t reply....
Old Dec 1, 2014 | 04:31 PM
Mike Ward's Avatar
Mike Ward
One is not better than the other, they each have good points and bad points. This statement will probably set off another beating of the dead horse.
In a previous post, you mentioned leaving out the springs. That's usually done when converting to o-rings. Most likely, me pointing out that this act displays a lack of understanding of why they're present in the first place which will start another war.
Old Dec 1, 2014 | 05:09 PM
C3s4me's Avatar
C3s4me
Gotcha!... Now I understand. Everyone wants to stay away from this topic because of known previous wars.....Less filling , taste great! Well I want taste great and if its less filling also that maybe ok too. But why settle for less filling if it taste like Chit!..........Thanks....
I am always willing to here a persons position but doesn't mean I will follow......r
Old Dec 1, 2014 | 05:33 PM
Paul L's Avatar
Paul L
A well-known problem with "personal" rubber products.....
To Rebuilding c3 calipers
Old Dec 1, 2014 | 11:53 PM
chvet73's Avatar
chvet73
I'm not really concerned what others say. Just offer my experience with both types of seals over 15 years of Vette ownership. I had constant issues with the lip seals of air in the system. Not one issue of any type and a nice firm pedal always with oring seals.
Old Dec 2, 2014 | 04:56 AM
mds3013's Avatar
mds3013
Right or wrong here is how I rebuilt mine. mike...
https://www.corvetteforum.com/forums...-calipers.html
Old Dec 2, 2014 | 10:05 AM
Mike Ward's Avatar
Mike Ward
My crystal ball says that you installed new rotors and didn't deal with the runout issue.
