72 front suspension
Old Dec 5, 2014 | 07:04 AM
bbcngineer's Avatar
bbcngineer
Default 72 front suspension
Team,
Got a situation brewing that I need some advice on. I'm resorting a 72 vert. It a driver project. It's led a hard life and will never be a show car. I just want to drive it and have fun with it. I have completed most of the mechanical work. Engine, tranny rear end and rear suspension VBP rear leaf, sway bar all new poly bushings. Was planning a stock rebuild on the front. One lower control arm is bent. The cross shafts are pitted to the point of not being round. Contemplating VBP front transverse spring for upgrade now that my stock stuff needs more replacement than originally planned. The cost delta is about 400 bucks more to do the whole suspension aftermarket than if I do original replacement. For an extra 400 bucks would you convert? Pros/ cons? Thought about coil overs, but a much bigger cost delta like another 1000 bucks.
Ideas comments please. This is the last step before paint.
Kevin
Old Dec 5, 2014 | 07:22 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by bbcngineer
...For an extra 400 bucks would you convert?...
No. I'd keep the stock system, but this is your car. If you want aftermarket, go aftermarket. The decision isn't up to any of us.
Old Dec 5, 2014 | 07:25 AM
Tripower delight's Avatar
Tripower delight
well for 400 bucks more your car will ride and handle better,or you can buy a new lower control arm,there pretty cheap its your call good luck
Old Dec 5, 2014 | 11:40 AM
69monzacpe's Avatar
69monzacpe
I'm also considering upgrading the suspension on my '69, so good luck with whatever decision you make. However, since you said your control arm was bent, be sure to check your mounting brackets for the lower arms to be sure the welds are good. My welds cracked and based on feedback from members here and some folks who work on these cars, the welding of these areas wasn't the best from the factory. I recommend you find a welder that has experience with frame welding and have them add some strength in this area.
My before picture:
My after picture:
They also did some spot welding on the bracket that runs under the cross member fore to aft.
Old Dec 5, 2014 | 11:43 AM
The13Bats's Avatar
The13Bats
Hard question to answer,
Some will say stay stock just because but you already modded so...
My new chassis came with all the VB transverse set up, it's sweet, I never would have bought it, I'm cheap but I got the chassis cheap,
If you go with the front transverse set up the car will handle and ride basically as good as a c4 which so many people like to boast handle and rode so much better than c3's so....
But the transverse stuff is old, now single coil overs on each wheel is todays cutting edge for c3's
If you are just going to drive the thing like a car...stock is fine.
Heck, people raced these cars basically stock....
Old Dec 5, 2014 | 03:21 PM
Hammerhead Fred's Avatar
Hammerhead Fred
You'll be amazed how nice a new stock rubber install performs.
My 72 is a daily driver and the fresh front end I installed 2 years ago makes it a pleasure to drive again.
Old Dec 5, 2014 | 03:29 PM
dochorsepower's Avatar
dochorsepower
Not only new stock rubber A-arm bushings but do some serious welding and gusseting on the front end. Another worthwhile addition is a 1-1/8" front sway bar.
To 72 front suspension
