Windshield moulding removal help needed
Old Dec 7, 2014 | 01:42 PM
danh77's Avatar
danh77
Default Windshield moulding removal help needed
What holds the upper mldg on a 77? I removed my side reveal mldg as it needs refinished and the channel appears to be in good shape but I have a question, there was quite a bit of black strip caulk in the area between the pillar and the edge of the glass but only up towards the top, is that normal and can I just repack it with caulk when I'm done or is there something else to use? I see no rust issues and have had no leaks when I ve driven in the rain so is there any thing preventative I should do before putting everything back hopefully the pic will show what I mean, most of the dum dum crumbled and I cleaned it out but it was basically from the top corner down about half way.
