fuel pressure regulator
Old Dec 11, 2014 | 09:48 PM
Madhatr's Avatar
Madhatr
Default fuel pressure regulator
Anyone running an adjustable fuel pressure regulator with their carb setup? If so do you have pics to share of how you mounted/ routed it? I need to set one up and would love some ideas!
Old Dec 11, 2014 | 10:00 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
I have one of these on a motorcycle with an electric pump and it works well. I tried to mount it as close to the carb inlet as I could. Mine was set at 5# (verified with a gauge) from the factory, but they are easily adjustable. Sorry, no pics.
http://www.summitracing.com/search/b...g&autoview=SKU
Old Dec 12, 2014 | 12:52 PM
my 76 ray's Avatar
my 76 ray
What kind of carb are you running? I have an Edelbrock and just mounted my regulator in line with the fuel line that came with the Edelbrock but that won't work with a Quadrajet without making new lines.
Old Dec 12, 2014 | 02:01 PM
Madhatr's Avatar
Madhatr
I'm running an Edelbrock carb as well, just trying to figure out what to mount the regulator too.. do you have any pics?
Old Dec 12, 2014 | 03:00 PM
Mike Ward's Avatar
Mike Ward
Wouldn't it be easier to use the correct fuel pump and ditch the regulator?
Old Dec 12, 2014 | 10:00 PM
The13Bats's Avatar
The13Bats
I have seen them mounted on a carb stud or on the inner wheel well with a little bracket, I was curious why you need one?
Old Dec 12, 2014 | 11:22 PM
redvetracr's Avatar
redvetracr
what fun is that...
Old Dec 13, 2014 | 12:35 PM
Madhatr's Avatar
Madhatr
Here is the situation... box stock edelbrock performer 650cfm performer carb, mild 350 (bored 40 over, world products torquerII heads, would have to go look up cam specs... I just don't remember them) and a 'stock' replacement mechanical fuel pump from one of the big box parts stores.
It never has run /really/ well, and it seems to run really really rich. I tried messing with the mixture screws to now avail, and when you get over idle speed (1500-2000 rpm) its like you turned on a garden hose in the primary jets. I've got raw fuel pooling in clearance pocket for the secondary butterfly's counterweights.. its a mess all over. My best guess is that the needle and seat are not sealing.. so either I've got some garbage stuck in there or too much fuel pressure. Edelbrock doesn't recommend anything more than 6psi, I checked mine and I have 5 at idle and a strong 10psi above that. My plan was to start with the fuel pressure and clean/re-tune the carb and see where I get, but any advice would be appreciated
Old Dec 13, 2014 | 12:41 PM
The13Bats's Avatar
The13Bats
I think the carb is messed up...not the pressure to it
Old Dec 13, 2014 | 01:33 PM
Mike Ward's Avatar
Mike Ward
No stock pump puts out 10 psi. Something's wrong.
Old Dec 13, 2014 | 01:49 PM
The13Bats's Avatar
The13Bats
Well yeah, but his problem from the symptoms he describes is what I have seen several Edelbrock carbs do, mine did it, pulled it apart cleaned it and it was fine, well, ( like all webers they hate trash, ) as fine as the Edelbrocks ever are, hence why I was asking about Qjet's and gonna move to them...
Mike, how about posting a picture of your fuel line pumping....
To fuel pressure regulator
