WWF reservior
Old Dec 16, 2014 | 12:22 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Default WWF reservior
Hey Guys,
Does a WWF tank and neck from a 1971 work as a direct replacement for a 1980?
Thanks.
Old Dec 16, 2014 | 12:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You've lost me. Is your replacement part stock for 1980?
Old Dec 16, 2014 | 12:49 PM
~Stingray's Avatar
~Stingray
hahah, thanks Mike. I left out the most important part. I fixed it. It was from a 1971.
Old Dec 16, 2014 | 01:06 PM
Easy Mike's Avatar
Easy Mike
I'm thinking the 80 tanks have the washer pump in the bottom of the tank. I don't think the 71 tanks have the built in pump.
Old Dec 16, 2014 | 01:07 PM
gbvette62's Avatar
gbvette62
"Direct replacement", no.
To start with, the 71 Corvette has it's washer pump mounted on the wiper motor, while the 80's pump is in the bottom of the washer tank.
You may be able to mount the bottle, but that would be the simple part. You'd have to replace your wiper motor with a 68-74 type motor and washer pump, or figure out how to install a 75-82 pump in the 71 tank, and come up with a way to trigger it.
Hardly worth the trouble, or expense, in either case.
Old Dec 16, 2014 | 01:44 PM
~Stingray's Avatar
~Stingray
Alright, thanks gays. This is what I needed to know.
Old Dec 16, 2014 | 06:25 PM
mrscott25's Avatar
mrscott25
Sheesh...guys try to help and you come back calling them names! Funny typo!
Old Dec 23, 2014 | 10:39 AM
~Stingray's Avatar
~Stingray
whoops! haha, well, hopefully no one was offended.
Old Dec 23, 2014 | 03:46 PM
redvetracr's Avatar
redvetracr
I have a bottle with the neck/cap/pump here off a 79 if your interested
To WWF reservior
