Steering issues cont.
Old Dec 19, 2014 | 09:39 AM
1rino56's Avatar
1rino56
Default Steering issues cont.
A couple of years back I replaced all front end bushings, tie rod ends etc. I also replaced the power steering control valve and swapped out springs to the 550lb springs. The steering now is so scary I barely drive the car. It feels as if the rear end is going to come around on any slight bend. Very little play in steering wheel, car appears to track ok. I have had the car aligned at three different shops, thinking it was alignment, but I have always felt it was a defective control valve or the alignment. My question, are the alignment specs different for the shorter/550 lb spring? Any other ideas? Merry Christmas to all in Vette world!
Old Dec 19, 2014 | 10:26 AM
SHARKBIT77's Avatar
SHARKBIT77
Get the back end up in the air and check your trailing arm bushings and rear bearings.
Old Dec 19, 2014 | 11:07 AM
JimLentz's Avatar
JimLentz
Did the problem start right after you made these changes?
Old Dec 19, 2014 | 11:08 AM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
If the rear bushings are bad the car can feel like driving a fork lift. It will try to steer from the rear. Very scary
Old Dec 19, 2014 | 03:59 PM
1rino56's Avatar
1rino56
yes, never had the issue before. And trailing arms have been rebuilt with about 5k miles on them over 5-6 yrs.
Old Dec 19, 2014 | 07:27 PM
cagotzmann's Avatar
cagotzmann
This usually is a rear suspension problem with the TA.
But if the rear TA is bad then you would also note extra tire wear. Since you dont drive it enough miles it may be hard to tell , but I would guess you have uneven tire wear in the rear.
Measure the tire tread depth on all 4 tires, they would be even if the alignment is set for street driving.
To Steering issues cont.
