TransGo Kit and C3
Now i have two options.
TransGo Performance Shift Kits 350-1-2
TransGo Performance Shift Kits 350-3
Motor is around 220HP so which kit would be best for me ?
As far as the type of kit, I think you want the '-1&2' type (not -3 which is race version). This is what I used.
I installed this kit last winter and it was a great little upgrade to the old TH350C. Holds onto first a little longer and shifts firmer. With my stock 2.87 rear end, I was/am not able to chirp the tires but that's ok.
The install went fine and I had never done anything like that before. I did break the drill bit that came with it, but just got another one. Be very careful, take your time and follow the directions TO THE T!
Jim
Jim
Info to read when installing
http://www.hotrodders.com/forum/th35...on-188578.html
I am confused as the tune up and service manual says Cali cars 1980 are 350C but the drive shaft is 6" long, no connector i can see.. Ill upload pics. the two VIN and code numbers are worn away..
