Engine Hoisting
Old Jan 5, 2015 | 02:27 AM
paragonspirit's Avatar
paragonspirit
Default Engine Hoisting
When lifting a fully dressed 350 from the engine bay, where is best to attach the hoist?
I can undress her if I must, but I am hopeful that the engine will come out of one car and directly into the next.
There is a ring with no apparent purpose at the front left near the intake manifold, but I would expect it to have a twin at the right rear and there isn't one.
I know this is insufficient information, what else can I provide?
Para
Old Jan 5, 2015 | 06:18 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Hi Para,
I'm not sure which year you are referring to, but you have described the lift bracket on the intake manifold that the factory uses. It has a brother that is located on the rear passenger side that should be connected at the bellhousing. Unfortunately, these are not good lift points for overhauls - the factory dropped the motors on the chassis with no body.
My suggestion is to use two inboard intake manifold bolt locations. Use long bolts with thick washers.
I expect you will be using a load leveler?
