T5 install into C3
My question is... as far as the shifter lining up correctly for the original style C3 manual shifter console, is it better to use a Gen 3 Camaro/Firebird style bellhousing with the 17 degree tilt towards the driver side or a normal bellhousing which mounts the transmission flat?
I know if I use the flat mounting I will have to buy an expensive offset shifter (to the left and forward) or modify/fabricate something for a stock shifter. I just don't know if the amount the Camaro mounting is offset to the left by the tilt makes it easier to line up with the console or not.
No need for an expensive offset shifter. A stock Ford T5 shifter has a straight shaft that can be made to function with a lil work.
Here's mine, since this pic I put the stock Corvette shifter on it so it looks more correct.
Edit: As good as this works, I originally had a Hurst T5 shifter. Unfortunately it came up to high into the console and couldn't use it. Have thought about opening the gate and getting a bigger boot but haven't yet, I like the stock look.
Seems straightforward enough... I have a welder but I am not sure it is up to welding that thick of material, its a 110V 70 amp wire welder.
It was different on the first one for the 68. Besides going to the left it needed to be lowered a little bit. Both were the Ford shifters bolted on to Camaro transmission's.
Just seems more simple and nothing to leak.
Either way, its a nice little trans and a fun project. Good luck with it.
Change of plans... I found a Camaro WC T5 for cheap... $260 including a flat mount truck SBC bellhousing with hydraulic clutch bracket. It included the Camaro shifter which I should be able to cut off and modify for offset and the clutch fork. So now all I need to find is the right flywheel, a clutch and disc, throwout bearing, the fork gasket, slave cylinder and the clutch pedal assembly and hoses and a yoke for the transmission... And the speedo cable adapter and the reverse light adapter... and a few other little things...
In an original automatic car, what is the best clutch pedal assembly to use? Should I buy a separate one, or one with a brake pedal on it too? Will one designed for a Camaro fit a C3 or does it have to be C3 specific? Where is a good place to find a clutch pedal assembly? Keeping in mind I plan to use a hydraulic setup instead of a mechanical linkage.
I had a 153 tooth flexplate, so I bought a 153 tooth (10.5) flywheel. IIRC you can shim your starter to accept 168 tooth flywheel.
EDIT2: I'm assuming here that clutch and flywheel must match, someone correct me if I'm wrong.
The only pedal setup I know is the stock one, where the brake and clutch pedals come together. In the time I contacted member Kustom8 about the seperate pedals he was making(allegedly you could put insert them in a automatic pedal box), but he responded months after I bought a complete set. I was 4 years ago and I can't even find the original thread. At the time he replied he still had some.
You using mechanical or hydraulic shouldn't change anything.
Pedal can be found on the sale section, but they are amongst the most sought after part, comes pricey.
Can't remember where I got mine, I guess it was Ebay.
Welcome to the GM T5 club, you can find pics of the rebuild/install of mine in my resto thread, check the first post, it has a master index.
You made a hell of a deal by the way.
Last edited by Denpo; Jan 29, 2015 at 04:39 PM. Reason: grammar, addenum, formating
I my case I made a deal on a lakewood scattershield. I probably could have gone the 11' way, but I was too scared so I stuck to the size I had. *chicken*
I dunno if 31-1/4" is the TH350 length driveshaft or if it is for a Muncie or T-10 or even a TH400 (all used during the C3 years).
From what I gather the T5 is approximately 1.9" longer than a TH350...
